0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I have a setup with a 54 pick up with a Hydramatic transmission. Trouble is I’m trying to replace the front transmission rubber mount but things seem to have dropped where I cannot sandwich in the upper layer of rubber, have you experienced this and did you if so did you find a solution. Should’ve mentioned I have already replaced the front engine in the middle engine rubber mounts
Thanks Todd | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I’ll check this out on my truck, tommorow or Friday. I’ll post a few photos. | | |
