5 members (TexasJim50, Peggy M, Woodcmiami, MickeyP, Hanks custodian), 83 guests, and 2 robots.
Topics128,059
Posts1,055,818
I have a setup with a 54 pick up with a Hydramatic transmission. Trouble is I’m trying to replace the front transmission rubber mount but things seem to have dropped where I cannot sandwich in the upper layer of rubber, have you experienced this and did you if so did you find a solution. Should’ve mentioned I have already replaced the front engine in the middle engine rubber mounts
Thanks Todd
I’ll check this out on my truck, tommorow or Friday.
I’ll post a few photos.
