7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible),
114
Mod | | | Forums66 Topics128,139 Posts1,056,460 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | I see quite a bit of info on Chevy serial numbers. It doesn't seem to apply to my GMC. Can anyone give me some info on my truck? The serial number is: FC1012XXXX | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | FC1012XXXX http://www.oldgmctrucks.com/page0010.htmlF = 1947-1950 C = conventional/standard cab truck 10 = 1/2 ton 1 = 116" inch (1/2 ton) wheel base 2XXXX = sequence number if you know the XXXX, then you can determine the year | | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | Cool thanks. Great info. Guess we can't tell where it was made. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have the engine serial number? | | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | Got it without an engine or trans. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Mark, where are you getting the serial number? Title? Frame? Not much info in the number like there is now-a-days.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I was wondering where he himself saw his serial number? I do see it's been decoded.
BTW: The data plates used during the era show: Pontiac, MI plant
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | Mark, where are you getting the serial number? Title? Frame? Not much info in the number like there is now-a-days. On the cab, drivers door jam between the hinges. I don't see anything on the frame, but it's difficult to see at the moment. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Is that a fairly large plate with black background that says GMC Truck Coach Division, Pontiac MI? Nice to have that still there. If frame is stamped, looks like it's on the side of the frame rail as opposed to later years being on the top of the rail. Tim's info also says right side, passenger side, as opposed to later years on driver side.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | Is that a fairly large plate with black background that says GMC Truck Coach Division, Pontiac MI? Nice to have that still there. If frame is stamped, looks like it's on the side of the frame rail as opposed to later years being on the top of the rail. Tim's info also says right side, passenger side, as opposed to later years on driver side. That's what my plate says, yessir. I'll take a good look tomorrow. | | |
