1 members (Lightholder's Dad), 66 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
I see quite a bit of info on Chevy serial numbers. It doesn't seem to apply to my GMC. Can anyone give me some info on my truck? The serial number is: FC1012XXXX
FC1012XXXX
http://www.oldgmctrucks.com/page0010.html
F = 1947-1950
C = conventional/standard cab truck
10 = 1/2 ton
1 = 116" inch (1/2 ton) wheel base
2XXXX = sequence number if you know the XXXX, then you can determine the year
Cool thanks. Great info. Guess we can't tell where it was made.
Do you have the engine serial number?
Got it without an engine or trans.
Do you have a chassis/frame serial number?
http://www.oldgmctrucks.com/page0013.html
Sir Searchalot
Sir Searchalot
Mark, where are you getting the serial number? Title? Frame? Not much info in the number like there is now-a-days.
Sir Searchalot
Sir Searchalot
I was wondering where he himself saw his serial number? I do see it's been decoded.
BTW: The data plates used during the era show: Pontiac, MI plant
On the cab, drivers door jam between the hinges. I don't see anything on the frame, but it's difficult to see at the moment.
Sir Searchalot
Sir Searchalot
Is that a fairly large plate with black background that says GMC Truck Coach Division, Pontiac MI? Nice to have that still there. If frame is stamped, looks like it's on the side of the frame rail as opposed to later years being on the top of the rail. Tim's info also says right side, passenger side, as opposed to later years on driver side.
That's what my plate says, yessir.
I'll take a good look tomorrow.
