5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#1303201 03/15/2019 11:09 PM
Who/whom are the best windshield and rear cab glass vendors out there for these old girls? Not looking for date coded glass. Prefer a tint bar...smoke glass as well. Also, is everybody in agreement that SoffSeal is the preferred rubber?
Sir Searchalot
Sir Searchalot
Windshield is Bob's Classic Auto Glass in Oregon. No shipping. Pick up at your local Pilkington.
Rubber: as Tim says. Steele the best, SoffSeal used by many. Bob's can supply Steele Rubber at a reasonable price when you buy glass.
Side glass, back glass: Classic Trucks of America and any other top vendor. Bob's may have a complete set.
OK...will check it out...thanks
Isn't the durometer number a high priority consideration when a pliable and conforming compound is key when glass meets rubber and rubber meets pinch weld...especially with the number of tight radiuses in these cabs. What is it about Steele products that stands out above others?
. . . What is it about Steele products that stands out above others?
They seem to match original shape/size better than other vendors.
They seem to install easier than products from other vendors.
Sir Searchalot
Sir Searchalot
I just blogulated on Steele Rubber quality.
https://www.stovebolt.com/ubbthread...3332/re-starter-bellows.html#Post1303332
Durometer does not have much to do with a windshield seal. Durometer is more of an interest in clamped gasket seals, flat gaskets, orings and such.
The windshield seal is a overlap flap and groove seal. Almost a static "sweep" seal. Watershed kind of thing. There is no mechanical compression/clamping.
Obviously the seals can't be rock hard or spongy soft. The dimensional stability yielded from the mold will make the product fit better. The quality of the rubber will make it last longer. Those are the main factors regarding off shore vs USA.
Durometer rating is more of a compression factor...my bad.
I recently checked out a local glass company to cut my glass from templates. Received a quote of $250. for windshield (2 pieces) and rear window. Checked other places but the shipping was
outrageous. Read a post online here and placed an order with Summit Racing. Shipping was free with an additional charge due to the large package size. Arrived undamaged, well packaged via UPS. Can't wait to see how they fit. Total for the 3 pieces of glass was $154.42 tax included.
Jeler that sounds good...although I'll be needing a one piece upfront.
2 Offline
another option for glass is you can bring an old broken one to your local window/glass shop and have them "cut to pattern"
i got new windshields and door glass made this way from a sample of the old ones
my local shop could offer any type of glass i wanted in 6 mm thickness, original non safety glass for side windows or tempered glass, laminated safety glass for windshield
each piece they cut and ground the curves and charged about $50 CAD (under 40 USD each)
also they had a few light tint options as well, but i wanted clear
6 mm is a tiny bit thicker than the original glass, but it installed no problem
-s
Sir Searchalot
Sir Searchalot
6mm is a tiny bit thinner than original, for most. That's why we have to be careful as to which tape we use.
2 Offline
oh yeah you maybe right, is the door glass is thicker compared to the windshield?
i got everything made in 6mm, the windshield rubber looked to be a bit stretched open because it seemed to be designed for a slightly thinner than 6mm glass
that's why i figured 6mm was thicker than original, but perhaps it is just that the rubbers i got are not exactly like original?
-s
2 Offline
attached some pics of the windshield going in, i wish i had a better photo of the tool i made to pull on the rubber, but it's nothing fancy, just has a rounded 90 degree tip about 3/16 inch long
the green tape was to keep the RTV silicon from messing up on the glass as i pumped a bead between the glass and rubber and rubber to cab body all around the outside
-s
Sir Searchalot
Sir Searchalot
I just know side glass on TF was .250 originally. 6mm is .236. TF windshields are molded curved. Not flat glass. I don't believe any AD would have been thinner than .250 and would not have been metric.
2 Offline
okay makes sense about the thickness, i wouldn't expect it to be metric
i'm not too worried about losing strength, the windshield is laminated and the other windows are easy enough to replace
-s
2-piece windshield would be a treat over wrestling with a 1-piece
