3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
Chief Bottle Washer
Chief Bottle Washer
Hello Gang,
I need advice on where I should locate my hoist chain to pull my 216 engine, out of my '52-3100? Should I use head bolt locations? If nothing else can you point me to the forum
thread that has this info already? I've looked...
Many thanks in advance!
Jim
Here is how I typically pull engines, with or without transmission.
Lots more pictures
Crusing in the Passing Lane
Any appropriately sized bolt will do, head bolts are fine if overhauling engine, manifold bolts are fine too, but will tilt engine unless hooked on both sides. Rocker cover bolts are pushing it, if not extremely careful-remove rocker cover, make sure bolts are threaded deep enough, spreader bar to only pull strait up.
Ed
headscratch
Forklift with wide fork?
Where's the chain fastened on the forward end?
Originally Posted by klhansen
...Where's the chain fastened on the forward end?
I am guessing it's fastened with an eyebolt replacing a front headbolt. I tend to use eyebolts but sometimes will fasten the chain right to the head with a headbolt. Usually I feel better about removing the rocker arm assembly so that nothing gets bent.
I have used a tow-rope or cargo-strap and just wrapped it around the engine like a sling. But this is probably not recommended.
For me a leveler is necessary, because the engine wants to rotate.
All that is required is one forged eyebolt attached to the third from rear head bolt hole. This removal method is directly from the Chevy maintenance manual. As can be seen, it balances quite well.
Lots more pictures
Paul, what page on which maintenance manual?
[I found your instruction in the pre-A-D manual, Step 17. What year is the truck/engine in-question in this post?]
Here is an illustration of the engine "lift kit".
Here are the lifting locations/instructions in the Shop Manual.
I have done it many times, with and without the transmission attached to the engine, using a "load-leveler" and a long-arm hoist (shop crane).
This leveller might work, however, I use this one.
Last edited by tclederman; 03/17/2019 3:05 PM. Reason: added links to pre A-D manual
I like to remove the rocker arm assembly and fabricate a couple of angle iron lift brackets that bolt to the rocker stand attaching holes. I use two holes for each lift bracket, with a total of four 3/8-16 Grade 8 bolts carrying the weight. A load leveler helps, also.
The engine/transmission in the picture is 1959/1947 respectively.
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm601.htm
Lots more pictures
1942-1947 - same page/illustration/-instructions as shown at my first link in the post above.
