| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | I am getting a 292 rebuilt for use in my '52 Chevy 3600. My question is if anybody has mounted one of these in an AD pickup? I need help finding an engine mount I can weld on for the offset passenger side bracket on the 292. Any help much appreciated. Also will I have to modify the rear mount being that the 292 is taller than the 216? Thank you. -Greg | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I will add,don't be put off by the $150.00 price. They are very well made and they fit,at least in a test fit for a future project.
Drew
| | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | Thank you for the link. As far as the transmission I'm torn between a saginaw/muncie 3 spd to keep the column shifter or a muncie 4 spd and swapping to a floor shifter. I would really like to keep the 3 spd on the tree but I don't know what gear ratios to look for. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | use a 55 chevy truck v8 bellhousing and a 54-55.1 bellhousing crossmember i am working on number 4 installation with a later model 250 or 292 in a 47-54 chevy truck i also sell the motor mounts and the adapter bracket to use the stock gas pedal linkage, the late 6 work well in the cars too. | | | | | Joined: Mar 2019 Posts: 2 Moderated | | Moderated Joined: Mar 2019 Posts: 2 | Do you still make the mounts and brackets John? | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Do you still make the mounts and brackets John? John hasn't been on the site for a few years. You can get the email address he has/had in his profile. Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2019 Posts: 2 Moderated | | Moderated Joined: Mar 2019 Posts: 2 | | | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | I have a set for my 53 1/2 ton. They have a 1/4" plate that brings them straight a cross from each other. They have a biscuit mount and a Cee channel that fits over the frame. I posted some pictures here a year or so ago. I can try to find them. I think ccp made them.
| | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | I have a set for my 53 1/2 ton. They have a 1/4" plate that brings them straight a cross from each other. They have a biscuit mount and a Cee channel that fits over the frame. I posted some pictures here a year or so ago. I can try to find them. I think ccp made them. My mounts were made by Chassis Engineering. Invoice #44948 on 12/6/16. I think they were about $60.00 I posted pictures here: The engine shop, 292 motor mounts, 23/12/17, 02:34 pm, #1247895
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If you want to keep the 3 speed/column shift, look into installing the 1970's Saginaw 3 speed with the synchronized 1st. gear. That makes 1st. a traffic gear instead of having to come to a full stop, and the earlier column shift linkage can be tweaked to work with the later model transmission. You might need to alter the driveshaft length, as I believe the Saginaw is a bit longer that the Muncie. The Saginaw is a bolt-in swap for the Muncie, as far as bellhousing bolt pattern and clutch splines are concerned. Jerry
