0 members (), 100 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
#1302987 03/14/2019 11:09 AM
According to the engine ID my 228 came new with .010 main and .010 rod bearings. I want to slap a new set in and wonder if anyone can decipher the bearings I pulled out? Google Web draws a blank. The numbers are as follows :
Mains
GMMA 6056 297D0
6057 296X0
6423 256D0
6059 216V0
Rods
GMMA 6055 T0
6055 T0
6055 U0
6055 U0
6055 S0
6055 U0
Crusing in the Passing Lane
Measure the journals.
Ed
Use a micrometer. A dial caliper (or even a digital) is only good for a SWAG. You need to make measurements of the journals you can reach for wear and taper down to a tolerance of .0005" or so. Unless the crankshaft is out of the block, it's difficult to get that accuracy on the main bearings. Drop me a PM and I can give you the exact measurements you're looking for.
Engine is in the truck and I don't plan on pulling the crank. I checked the clearances and they are acceptable but definitely on the loose side. The head is out being redone and I want to do quickie rings and bearings while it's off. I don't know much about the truck. Supposedly it was sitting since the '80s.
Like the Sun test equipment slogan used to say- - - -"We Test- - - -Not Guess!"
I agree with the need to measure. Also, every undersize bearing shell I've seen was so stamped. Std size are not so marked. I have also never encountered a GMC with factory undersizes. Maybe a rebuilder???
