| | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | According to the engine ID my 228 came new with .010 main and .010 rod bearings. I want to slap a new set in and wonder if anyone can decipher the bearings I pulled out? Google Web draws a blank. The numbers are as follows : Mains GMMA 6056 297D0 6057 296X0 6423 256D0 6059 216V0
Rods GMMA 6055 T0 6055 T0 6055 U0 6055 U0 6055 S0 6055 U0 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | Use a micrometer. A dial caliper (or even a digital) is only good for a SWAG. You need to make measurements of the journals you can reach for wear and taper down to a tolerance of .0005" or so. Unless the crankshaft is out of the block, it's difficult to get that accuracy on the main bearings. Drop me a PM and I can give you the exact measurements you're looking for. Jerry
| | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | Engine is in the truck and I don't plan on pulling the crank. I checked the clearances and they are acceptable but definitely on the loose side. The head is out being redone and I want to do quickie rings and bearings while it's off. I don't know much about the truck. Supposedly it was sitting since the '80s. | | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | Like the Sun test equipment slogan used to say- - - -"We Test- - - -Not Guess!" Jerry
| | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | I agree with the need to measure. Also, every undersize bearing shell I've seen was so stamped. Std size are not so marked. I have also never encountered a GMC with factory undersizes. Maybe a rebuilder??? | | |
