2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1302616 03/11/2019 1:31 PM
On my '49 Chevy 3100 1/2 ton the part in the picture was under the bed and attached to an angle iron brace spanning between the frame members. It is obviously cut off. What function did it serve and what is it called?
best regards,
Joe
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
I cannot ID the part, Joe; however, my guess is that it was part of the spare tire carrier?
Is there a spare tire carrier under the bed?
Spare tire carrier piece. Too light of metal for part of a trailer hitch.
Sir Searchalot
Sir Searchalot
Does not match spare tire carriers on Ebay. If it was attached to an add-on/non original "angle iron" cross member, it's not original. Also depends on where under the bed. Front middle rear. And what direction the cut off was facing. Except for light construction as Martin said, I would have guessed trailer hitch. But the part has unique, era correct form.
Joe S. #1302683 03/11/2019 11:33 PM
7
7 Online: Content
Maybe an add-on exhaust hanger.
Joe S. #1302691 03/12/2019 12:12 AM
That is a section of a slider for spare tire carrier. Looks like most of it has been cut off
Where?? I need one (eventually).
Its what 52 Carl said. My truck still has the piece under it.
Sir Searchalot
Sir Searchalot
Kevin.......this is what I found for sale. Pic 1
https://www.ebay.com/itm/1-USED-ORI...DER-BED-SPARE-TIRE-CARRIER/153405156925?
Joe, as Carl confirmed and was said by others, It's the slider. It's a piece of what is sometimes called the "track", for the carrier.. Not shown in the Ebay pics.
Mounted just like you said. Pic 2
Thanks, but I have a '51 that takes the swing out style. I have one from a '72 Chevy that I may try to adapt. One of the members sent me some dimensions off his. thumbs_up
