6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#130261 07/23/2004 4:24 AM
Z
Junior Member
Junior Member
Z Offline
I recently picked up an S-10 rear end to put in my 37 1/2 ton. Is there any problem using the stock 37 springs (I like the ride height)or should I use the late model S-10 springs which are currently with the assembly. Thanks for any help.
#130262 07/23/2004 11:15 AM
The stock type springs will work ok if you install the axle over the springs like stock.The S10 springs are wider , have less leaves ,and less arc which is good,but would require reworking the existing 37 spring hangers.
