4 members (Hotrod Lincoln, Gray_Ghost, cmayna, dt235sd), 119 guests, and 0 robots.
Topics128,051
Posts1,055,732
#1302499 03/10/2019 7:28 PM
Hi Stovebolt folks
I have located a possible new project...located in the middle part of the country (I am in upstate NY)...so it looks just like a 1951 Chevy 3600 but the grille shell says GMC...it has the standard 235 cu in motor under the hood...it appears to be a minimally molested original truck..it is lacking rear brakes but the current owner tells me it will run up on a car trailer...I have had several Chevy trucks of this era in my past...so how close is the GMC to the same year Chevy???
Any insight would be greatly appreciated...
If I was to get it...maybe switch the rear end out for a better gearing and maybe put better brakes on the front axle...a 3 point seat belt harness too...
thanks in advance...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
62401
Mike -- I think some pictures and a VIN would be helpful for the gang to tell you more about it and to answer your questions. It's hard for anyone to give you much insight without seeing what you are seeing.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
A GMC with a Chevy 235 in it is often a Canadian GMC.
1952 Chevrolet 3800 pickup
---All pictures---
Fox Offline
If it is a Canadian GMC, as Grigg said, the front of the frame is the same as a Chevrolet. This IS NOT the case with US trucks from what I’ve been told. I swapped a Canadian GMC frontclip onto a Chevrolet frame with no issues. Something to think about if you learn more about it before pulling the trigger on the sale.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
If it is a 1951 3/4 ton Canadian GMC with the "normal" Chevrolet" engine, I doubt that the 235 engine under the hood is/was the original engine?
As John asked in the second post:
What is the engine serial number?
What is the block date casting code?
Engine pic
engine pic
3/4 front view
interior view
Partial VIN tag pic
front view
I will check with the fellow on the engine block serial number
I think what is throwing me off is under the hood the darn thing looks just like the last 3 or 4 that I have had...the dash even look the same
I have a couple more pictures that he sent me...it reminds me a lot of the 1 ton I had except the bed is only 8 foot...which is not a bad thing...it would fit a little better in my garage...
MikeC
Howard Knapp
It looks like it was built in Pontiac, Michigan from the door tag. So I have to wonder if that is a GMC 228 or 248 engine?
The engine is not a GMC engine - wrong valve cover.
It is a high-pressure 235/261 Chevrolet engine.
The engine serial number that is pressed/stamped into the block at the rear of the distributor should help to ID the engine.
62401
Gents -- Are the gauges correct for a GMC??
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
It's probably a 235. Somebody may have swapped it in to replace a blown 228. My '53 GMC currently has a '49 216. It happens.
The front sheet metal, horn button and "General Motor" speaker cover suggest it's not a GMC "clone"
The heater vent louvers on the cowl side have been oddly modified.
Yep, the Chevys and GMCs are basically the same truck with a few differences. Engine, grill, front cross-member, negative ground, and a few other very small differences.
The gauges were a light brown in early years, but I believe they were changed to match Chevys in '51
Wouldn't original GMC oil pressure gauge go to 60 lbs. as opposed to Chevy 30 lbs. ?
Yes:
GMC 0-60
Chevrolet 0-30 (47-53)
I think I see 0-60 on the interior pic.
68ironhead is correct.
0-60 after-market replacement gauge-units are available from reproduction parts suppliers
Fox Offline
Do you have a picture of the frame front from the underside? That will help solve the frame question.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
We’re the canadian GMC’s engines (that had chevy engines) mounted to a gmc front crossmember or Chevy crossmember?
1946 GMC Project
"Back-in-the-day Restore"
The GMC motor is 1 1/2 longer than Chevy.
Look at the frame mounts to if some has done something to the frame mounts ?
Chevy front cross member is not the same as gmc.
Look at the radiator mount to see if someone put a GMC clip on a Chevy?
If you post a pic of the radiator mount from the front under the valance I maybe able to tell you.
Most of the GMC's had a u bolt style mount.
Rob English posted (in 2006) an excellent side-by-side comparison of New Design vs Advance-Design frames forward members:
https://www.stovebolt.com/ubbthread.../filename/GMC_Chevy_FrontCrossmember.jpg
Crusing in the Passing Lane
GMC engines are about 3" longer that Chevy's, so see if your 235/261 has large fan to radiator clearance.
Ed
Everything I see except the engine tells me it's a GMC. The engine is a 55 or later Chevy 235 with the low long-shaft water pump. It fits in there okay since the GMC radiator is more forward then a Chevy. The serial number tag is a USA tag as has been mentioned. Cool truck! Enjoy it.
Professional Novice
I talked to the fellow yesterday in search of more pictures...the truck is out in the rural part of Nebraska and I guess where the truck is stored is at his inlaws house...so not sure how far apart they are...We will see maybe this weekend if he gets me any more pics from the underside....
I was thinking with the Chevy dashboard on it...maybe it got in a wreck back in the day and they swapped the front sheet metal...but why would they swap the VIN tags too???...hmm
Gonna have to wait and see....
thanks for all the insight tho...
MikeC
Passenger side
rear window view
Howard Knapp
There's nothing non-GMC about the dashboard.
Is the seller calling it a Chevy or a GMC? Does he have it titled as a Chevy or GMC? The only Chevy thing about it I see is the engine - and engines got swapped often...
There are a lot of hodge-podge trucks out there put together with parts from other trucks. Lots of interchangeability over several years within that series.
You should verify that the VIN/ Serial Number on the truck and on the Title match.
Professional Novice
"I was thinking with the Chevy dashboard on it...maybe it got in a wreck back in the day and they swapped the front sheet metal...but why would they swap the VIN tags too???...hmm"
As Frank50 posted - they dashboards are the same, except for, maybe:
- oil pressure gauges (0-30 vs 0-60)
- ammeter vs voltmeter (I am not sure)
V
V Offline
The gauges in my 49 GMC 100 are nearly identical to the gauges in my 49 Chevy 3100. OIl press = 0-30, ammeter and gas level. The difference is in engine temp where the Chevy goes to 212 and the GMC goes to 220.. Other than horn button and the script identifying the manufacturer the interiors are also nearly identical.
re. swapping the front clip. There would be more involved to put a GMC from clip on a Chevy than just bolt on as the front clip-to-cross member attachment is different. You can see the differences in the pics posted above of the differences. It can be done but it would be alot of cutting and welding work.
IMHO the GMC with it's slightly extended engine bay clearance is better suited to later model engine upgrades, if that's what one wants to do.
It's not unusual to find Chevy engines in GMC body's.
Without the engine numbers its hard to say but I'll swag someone dropped a 216/235 engine in a GMC.
It's difficult to read from the picture, but I think the radio speaker grille has GENERAL MOTORS TRUCK which is correct for a GMC. It would read CHEVROLET TRUCK for a Chevy.
I'm sure trying to buy this truck sight unseen, relying on pictures and the seller's description and comments, is risky. It's always best to deal in person, but sometimes that's hard to do.
Professional Novice
