1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 52 Member | | Member Joined: Mar 2002 Posts: 52 | I am going to run a 350/300hp in my 51 3100 truck with a camaro front clip. I think with the 9" f-rd rearend and the 350 tranny that I should box the frame for a more substantial solid frame- is this worth the effort? or would a couple of cross members do the trick? Any info would be great- if so- where can I get a pre-cut steel kit? | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I boxed my 39 frame but mostly for the look. Probably not necessary if the front of the frame was boxed when your clip was installed. An extra crossmember would probably do the trick. Pre cut kits http://www.progressiveautomotive.com/Boxing.htm | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I would definitely consider reinforcing that front end for several reasons: 1) you've added considerably to the total weight of the vehicle; 2) regardless of how good a job you've done structural integrity has to be weakened somewhat by the clip graft and 3) that powerful SBC is going create some significant torsional stress on the frame. My advice box it. Good luck | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Steve, i clipped my 39 with a camaro clip and i plated the stock frame to the clip with plate steel. I also plan on adding some kind of k or x member to the center of the truck to tie everything together to keep them framerails from twisting. Then again this is my first truck project, so what do i know..............Thats why I joined the site....Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
| | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Steve, I also see that we are neighbors here in Somerset county,probably pass you by in Somerville on Friday nites.
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Dale...sounds like a great project...my current project is a '52 Suburban (former Kansas school bus) with a 350/330hp crate and a TH400,MII IFS w/ PS (boxed) and GM power discs all around...other than that it will look absolutely stock. See you at Somerville in the Spring or at Spring Englishtown...I'll be the guy selling the Chevelle Bumper Jacks. | | | | | Joined: Mar 2002 Posts: 52 Member | | Member Joined: Mar 2002 Posts: 52 | Excellent info guys, thanks! I think I will box it- can't go wrong- never know when you have the need for more hp. | | |
