BUSY BOLTERS Are you one? The Shop Area
Topics126,778
Posts1,039,291
Members48,100
Most Online2,175Jul 21st, 2025
Hello all, can anyone tell me what rear diff I have here. It is non original on a 41 g506. Thanks
Hy 1941G506, Welcome, I believe that is a Chevrolet (Timken) double reduction two speed, correct for the period, hope that helps
Yes, I believe your right! Any idea of model or where/ what wheel cylinder she needs?
Awesome thanks! Any idea what wheel cylinders it takes?
Hy 1941G506, as we don't know what the original application was there is no way to tell how it is equipped until we take it apart for an inspection
Is your intention to source the correct rear axle for your G506, or simply replace the wheel cylinders in the axle you currently have?? Originals are available, including via ebay... just search for 'Chevy G506 axle'.
WW2Chevy 1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch (Retro-roco)
Crusing in the Passing Lane
Most older two speeds are slow and slower ratios, so it might be useful to look for a newer two speed that fits your bolt pattern. Ed
