4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#1302244 03/08/2019 9:03 PM
Hi - just a quick question pertaining to identifying engine: What does it mean when the serial number location next to distributor is blank?
I purchased a rebuilt block in 1983 and it is also blank. So either rebuilt or maybee a new engine from gm.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Two choices come to mind. Crate engine that failed to get stamped prior to install or someone ground/machined it off. I’m sure there are more explanations to come.
New engine might fit story from previous owner - he had said it had a replacement engine installed.
