7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible), 57 guests, and 2 robots.
Topics128,059
Posts1,055,820
#1301707 03/04/2019 7:56 PM
Like so many of our older rigs I know of a few areas of rusty surfaces such as down inside the doors, lower interior side of rear cab corners, etc and want to stop it from doing more damage. There are so many different brands out there. Corroseal? Evapo-Rust Ultra? Rust Converter Ultra? My truck is a daily beater so no plans to do a bunch of body work nor paint it.
What might you recommend?
Craig
I have had excellent success with POR products in those locations, after careful preparations, and careful application.
Scrape/rough-sand-off any loose material.
Apply/use a cleaner degreaser.
Apply the rust preventative coating.
Apply the POR top coating, or, apply the primer you will use with your top/final coat of paint.
Follow carefully all product sheets, for each product.
For areas like inside doors, I get them as clean as possible, apply Ospho, then wait 24 hours and paint with Rustoleum Rusty Metal Primer, then paint with Rustoleum paint (any color).
I used Corroseal and was happy with results. I think any of them will do the job if you follow instructions.
Dave from Northern Kentucky
My 54 3100
Just curious, what happens if you treat with rust converter and leave it? I’m talking places that aren’t seen or are hard to get at. Can you just OSPHO the dickens out of it, rinse it off and forget it forever?
It depends on the rust converter.
does+rust+converter+need+to+be+coated+sealed
Ospho - might as well over-coat?
"Painting treated surfaces tends to yield more durable finishes, as moisture and oxygen are effectively sealed away from the metal."
Thanks all for some ideas. I did a bunch of web surfing on ospho and most everyone said that if you don't paint over the ospho, it will create a thin film of rust. But remember.......that's the web talking. So far I'm most impressed with what I've seen regarding Corroseal.
Craig
I've used Eastwood's Encapsulator a bunch. When it came time to sand my roof for epoxy primer, it was a BEAR to get off!!
I have used chassis saver it is simular to por 15 without the prep except for scrape and sand the loose rust off. Seems to be okay so far it is hard as a rock has to be painted over if exposed to the sun.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Used POR for years but it is so hard we had top coat adhesion problems on occasion. We switched to the KBS system which also dries to a shiny black finish, seems to encapsulate just as good, and has not had a top coat adhesion problem. The noise you hear is me knocking on wood.
Evan
Seven years ago, we carefully followed the re-coating and over-coating instructions for the POR products, and, the coatings are having no problems on the long bed-boards and long frame on my 54/55 GMC.
Does fiberglass filler or long strand fiberglass adhere to cured POR? I have POR on my frame but I am thinking of smoothing it where it pitted. Not too concerned - just curious..
1946 GMC Project
"Back-in-the-day Restore"
I have used fiberglass cloth with the chassis saver no resin just paint and it stick and dries hard as a rock. I used this on my ford ranger floor were the floor was getting thin and it so far has worked great for two years now. I seen this on u tube and gave it a try.
"The Journey"
Follow in the DITY
For near impossible to reach areas use a cavity wax aerosol. 3M and others sell them. Spray a healthy amount and keep on truckin'.
If you think about it, rust needs oxygen and moisture to continue so if you cut one or both off, you've done the best you can.
POR 15 and fibreglass are not the answer.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
