| | | Forums66 Topics128,078 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I just bought a mechanical aftermarket gauge and the probe (sending unit) is so big it hits the thermostat in the housing...is an ELECTRIC probe SMALLER? THANKS! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Electric probes are not usually smaller. You can, however, use a pipe nipple to connect the sender to the hole and keep it out of the way. Or find another location.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Thanks... I went with a mechanical. 270 degree sweep on the dial compared to only 75 degrees sweep on electric. The mechanical is supposed to be a quicker responder to changes also. It was more time-consuming to install,but I like it! | | |
