0 members (), 150 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
I just bought a mechanical aftermarket gauge and the probe (sending unit) is so big it hits the thermostat in the housing...is an ELECTRIC probe SMALLER? THANKS!
Electric probes are not usually smaller. You can, however, use a pipe nipple to connect the sender to the hole and keep it out of the way. Or find another location.
Paint & Body Shop moderator
Thanks...
I went with a mechanical. 270 degree sweep on the dial compared to only 75 degrees sweep on electric. The mechanical is supposed to be a quicker responder to changes also. It was more time-consuming to install,but I like it!
