2 members (Otto Skorzeny, 1 invisible),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 14 Member | | Member Joined: Feb 2002 Posts: 14 | The Classic Performance website has instructions for a GM steering column installation. They recomend cutting the steering column shaft down to 31 1/4 inches. Why? Also, how tough is it to get the steering column shaft out of the steering column? | | | | | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | You don't take the shaft out. What you do is cut the lower end of the mast off higher up than where you want to cut the shaft. Then cut the shaft, make sure to do a good fillet weld. I like to run a sleeve over the joint and weld it also. The shifter tube also needs to be cut, if your not using a column shift use a piece of filler to weld it to the outer mast. When that's done weld the shortened lower mast back together and your done. CAUTION be sure to remove the nylon bushing on the bottom of the mast as you don't want to ruin it with heat. Another tip, use a piece of angle long enough that it will hold the shaft straight for welding. | | |
