| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | I have front fender turn signals that bolt on the fenders of my '54 6100. I am wanting to replace these with new LED versions. They are 4" in diameter. Where are these found and what is the right term for them? I found lens for the ones that were originally on it. Those lenses are in bad shape and need to be replaced but if the LEDs are cheaper, I'll go that route. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You can still buy fender turn indicators from Trucklite, Petersen and Grote but they will be square instead of round. Are you looking for something just functional or do you want something to look original. If that is the case, you will probably have to go NOS or used and they will be incandescent. | | | | | Joined: May 2015 Posts: 11,046 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,046 | Trucklite has round ones still that look similar to the original fender pedestal mount light. LinkPeterson also has a similar LED pedestal mount. LinkDidn't find a similar one in Grote's offerings.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | If you wanted to maintain the original appearance with the period correct lights (like the arrow kind), it probably wouldn't be hard to retrofit an LED light source into them as is being done with the regular tail lights for our trucks ....
Someone on here may have already done it ... ?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | The ones that I have don't have arrow indicators on them. They are just plain amber round. The model is Guide D6-52A. | | |
