3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | Hey I was just about to order five Dexter AM20761B from eTrailer when the sales person said their rims should NOT be used on any vehicle …. only trailers. This is the first I've heard of any such limitations. Is it okay to use these on my 1956 3600 truck guys? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | They are not DOT approved for motor vehicles. ðŸ›
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | It's absolutely fine. I bought a set of 15's a couple years ago and they're excellent. Powder coating is so thick you can barely see the "trailer use only" stamping- you have to know where to look. As far as safety is concerned I feel more confident with them than my original 16's that are usable but you know how it is after 67 years...minor dings here and there, maybe a smidge of runout, not to mention I'm running them without tubes and they're riveted. I also think they're harder to balance. There's no rivets in the modern wheels and they also have the bead retainer ridge and undoubtedly made to a tighter spec than wheels from almost 70 years ago and don't need the massive balance weights my 16's always seem to need. I say from my own experience--buy with confidence.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I have a set of 16” 8 lugs on my 1 ton. I have 600 miles on them now. Good so far.
However, one thing I didn’t like was the back side of the wheel had welding spatter underneath the powder coating. I feel that stuff should have been cleaned up before paint. You never see it but it still bugs me. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Trailer-rated wheels are actually stronger than passenger car ones- - - -but without the DOT number on them they're technically not approved for vehicles. It's all a bunch of C-Y-A for the manufacturers, insisted upon by the legal beagles and the bean counters who are deathly afraid of lawsuits! Jerry
| | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | Great, I'm going to buy them based on your comments.. Thanks guys. | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | One word of caution, "backspace". I'm running these on my '51 3600. They have .5" backspace and Just do clear the tie-rod ends, actually have a touch mark on one inside wheel weight. In looking at your wheels I didn't see the offset. Might not be an issue since your truck is a '55, just something to be aware of.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | You could probably run a 1/4" thick spacer plate behind those wheels and solve that problem, without having to go to longer studs. Jerry
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Aren’t most trailer wheels zero offset? I got these, zero offset if I recall, and plenty of clearance on my ‘52. https://www.etrailer.com/s.aspx?qry=AM20514
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Agree.........they are 0 offset............plenty of clearance. There one or two rims with .5” offset. meets Department of Transportation standards............appears on all the rims. Key point made earlier.........There's no rivets in the modern wheels and they also have the bead retainer ridge and undoubtedly made to a tighter spec than wheels from almost 70 years ago and don't need the massive balance weights my 16's always seem to need. I say from my own experience--buy with confidence. thumbs_up
