| | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | Hello Bolters-
I'm rebuilding a 56 Chevy pickup with the standard 3 speed synchromesh transmission (3 on the tree). Found a busted gear and am hoping someone can help me find a servicable one.
What I need: a Countergear (tooth count: 27-14-22)
What I'd like to have if I can find: Rebuild kit Input shaft Reverse Idler Gear bushings and shaft
I've called everyone the local experts recommended, but no luck. These things are getting hard to find. If anyone can help or point me to someone I'd greatly appreciate it.
Thanks! Joe G Midland, TX
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | you may find these parts by typing into the search box on Ebay or a replacement three speed for parts or a swap too.
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Joe, Contact Dave or Jim at: Waugh Transmissions, 11965 Rivera Rd. Santa Fe Springs, CA 90670 562-693-0855
The counter gear is now being reproduced and is available. The other components are also available from them. Fred
| | | | | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | Thanks Fred-
Just talked to Dave. Turns out I have a Muncie 318. Looks like he's got the parts to get me back on the road. Awesome!
Joe
