2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#1301003 02/28/2019 12:36 PM
My choke has been abandoned and no longer needed. I want to install a simple switch in its place. My issue is the nut on the backside of the dash holding what's left of the choke housing is seized up. With the knob and shaft removed can I just carefully drill out from the front through the center hole until enough material is gone to remove completely. Am I missing anything.
V
VEW Offline
V Offline
I understand you are talking about the choke cable located in your dash, and you want to remove it. Have you tried a rust buster like PB Blaster? I would try to see if I could loosen it up before I started drilling. I don't know if it is a notched escutcheon or not; ie, is the whole in you dash round, or does it have a notch in it that the cable slides into?
Some things to consider before bringing out the hardware, IMO.
~ Victor
1957 3100 - moved on
I understand...I'll throw some PB Blaster at it and let it set a day or two...no hurry for sure. Am I right thinking the nut threads off by design? Can't tell if there is a notch in the escutcheon can't see the backside. I'll get a mirror and try and get a good look.
Moderator, Electrical Bay
I think Kroil is the best and Liquid Wrench isn't too bad for a less effective option. Kroil is expensive, but it works much faster and you use less of it. Get the liquid Kroil in a can and it will last longer...it does not expire, but the aerosol cans can lose pressure over time and I think the product inside them has been diluted a bit.
~ Jon
Kroil is OK...used it extensively when working as a Pipe Fitter @ a 1400 megawatt power plant years ago. I like Blaster because of its clinging ability. I won't think the aerosol version is diluted down. They are positively better than WD-40 for sure.
There was a product made in East Texas 20~25 years ago but sadly it is no longer available. Rumor was the EPA made them stop using some ingredient in it. I never saw it sold anywhere but through HVAC supply houses and it worked like magic. I remember buying it from the 80s up until the mid 90s or so. You'd apply a few drops, finish your coke/coffee/etc and then you could unscrew rusted nuts, bolts, screws with ease. The idea of waiting a day or two while that stuff soaked in? Nope...it was made so guys could finish their work fast and get out of the sun. Even back then it was about $9 for a 2 or 3 ounce bottle but you didn't need much.
~ Jon
7
7 Offline
I've been using Sta-Bil spray fogging oil as a rust penetrant, it creeps in pretty well.
The Choke hole is round...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Nice looking dash...factory perfect. All original build? Thanks for the look...I still may end up taking my time and carefully drill out the escutcheon.
If you're going to trash the cable housing anyway, just drive a square flute EZ-Out into the hole and grab it with vise grips while you turn the nut off the back side. If that doesn't work, then drill.
Yeah its history. I'll take a look at my limited EZ out selection...but good idea. Will be my first order of business in the morning.
Thanks, it's in my '56 3100 restorod...
Report back with your progress!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
GOT IT! no drilling needed. Had a socket set with pass-thru feature so you can work any length bolt, stud, etc. Just the ticket.
thanks
