4 members (Otto Skorzeny, Jon G, JacobU66, 1955 1 Series), 69 guests, and 1 robot.
Topics128,026
Posts1,055,399
Members48,422
#1300459 02/25/2019 12:36 AM
a few years back i replased the org motor in my 51 3100 with a 250 in line 6 t5 speed trans and camaro 323 rearend im starting to feel the need for a little more im thinking 5.3 and auto trans any thoughts or input bad or good would be helpfull
shade tree #1300530 02/25/2019 2:35 PM
That 250 has got a lot of pep and should be able to push your ‘51 along nicely. Are you now wanting to race your truck?? Seems like a lot of work to make the swap, but it’s your truck.
My 2 cents worth.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
shade tree #1300543 02/25/2019 3:53 PM
Drop the rear end ratio a little would help a lot, and lot easier.
My Blog
shade tree #1300555 02/25/2019 6:19 PM
Or drop a lot since you have OD! I'd say 3.73 at least, since we have grades to pull in my part of the world I'd got 4.10:1
BC
1960 C60 pasture art
shade tree #1300609 02/26/2019 1:08 AM
thank you one and all the more input i get usuly the better i decide
Pre '68 Dave #1300629 02/26/2019 2:09 AM
Doesn't he want to raise the "ratio" ? (3.73 to 1 is a higher "ratio" than 3.23 to 1).
I know what you mean, I just want to make sure everyone else does.
I have heard of 3.73 to 1 rear end as being described as lower "gear", and a 3.23 to 1 rear end as a higher "gear", and I am fine with that.
Carl
shade tree #1300645 02/26/2019 3:03 AM
Most every one I have ever talked to says lower ratio, as in this case.
I know that means lower speed ratio, not numerically as you point out wink.
My Blog
shade tree #1300649 02/26/2019 3:16 AM
When I saw the title I thought maybe someone was trying the Cummins Repower smile.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Lindsey #1300677 02/26/2019 11:32 AM
Moderated
Moderated
I am planning to use the Cummins Repower on my 50 6400
