1 members (RBs36),
172
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 44 | I knocked the rear end and springs out of my "52 long bed and need to install the new brass bushings / pins. Several of the old bushings are worn almost through. One old mechanic told me to file / grind through and then collapse the old bushings to help remove them. Going through them and marking the inside of the shackles worries me. I'm sure someone has figured out the best way to accomplish this task. As well as the best way to install the new ones without distorting them.
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I guess you mean a 3/4-ton truck: The shop manual has a procedure for this, but your old mechanic friend's method may work as well. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0461.htmI have had three 3/4-ton A-D trucks but have not done this repair.
Professional Novice
| | | | | Joined: Feb 2014 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 44 | Yes it is a 3/4 ton. Thanks | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | they come out surprisingly easily a tiny 5 ton press a big vise threaded rod with sockets or cut with a hack saw gently, the spring is so hard you won't really affect it if you reach it, you don't need to cut all the way through the bushing, 90% is good, then start hitting it with a hammer and a steel drift i used a chisel to cut one out, i had a high quality 1/4 inch one that sliced it like butter
the bushings are standard sizes, don't buy special bushings for the truck at places like LMC or ClassicParts, they are way too expensive go to McMaster Carr and find them for much less $ by size. 2868T192 High-Load Oil-Embedded SAE 863 Bronze Sleeve Bearing for 7/8" Shaft Diameter and 1" Housing ID, 1-1/2" Long 6381K561 Multipurpose SAE 660 Leaded Bronze Sleeve Bearing for 7/8" Shaft Diameter and 1-1/8" Housing ID, 2" Long
you can cut 2 bushing to make a longer one for the top of the shackle position -s
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | the parts numbers above are for 3/4 ton and 1 ton trucks, i don't know about the 1/2 tons -s | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | A couple of pieces of pipe, some all-thread rod, flat washers and an impact wrench will make a field-expedient press that will remove and install the bushings with the same tool. There's no need to cut them to reduce the press fit. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2014 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 44 | Thanks, I appreciate the info. The next problem is finding the time to get back to it. | | | | | Joined: Feb 2014 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 44 | Many thanks to 2ManyTrucks. I just ordered my missing upper bushings from McMaster-Carr and they were great to talk to. I appreciate having all the necessary information to place the order and the price was very reasonable.
Eugene
