0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Hello, First, are the "GMC" doors the same as Chevy truck for the AD years? Second, how are the doors removed? (6 bolts on cab or 6 on door?) Easiest way? I have never removed an AD door. Any input would be appreciated.
//Thank you. I may have the opportunity to get a set of doors for free, but they are on the cab. Which I will have to remove.
Great Info, Thank you. The doors are totally complete, with glass and even arm rests. How heavy would you guess one door weights? Again, Thank you for your input! *****Update: got the doors off. Only three hinges. Driver's side upper would not come out??? (Looks like a pin is sticking up top left.) How would I remove this? Also how do I confirm the hinges are Original? Marks ECT? I have to go back and grab a few more parts.
1950 Chevy 3100
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | I believe Chevy and GMC doors are the same, but hopefully an expert in this area will chime in to confirm. Do you have access to an engine hoist? I have remove both of my doors to install new weather stripping by using an engine hoist. I lower the window down and run a couple large nylon straps thru the window opening and up to the engine lift's hook. I'm sure there are other ways and hopefully will jump in and give you more details. Here's a pic of my door dolly: [img] http://www.cmaynard.com/Truck/TruckDoorDollyB.JPG[/img]
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | First: yes
Second: either way
Take the bolts on the door off first. Pull the door off the hinge.
You will have to adjust the door bolts in order to get each door to match the cab opening.
Replace the hinge “springs” if necessary.
If the hinge pins are loose, you will have to deal with that common reality. Ask about the options, it they are loose.
| | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | You can disconnect either way. I think the easiest way is to remove the bolts from the door. When you remove the bolts from the jam, you end up wrestling a heavy door where the hinge, broken spring, wrong angle, etc might hang you up. Removing the bolts from the door gives you a single plane for removal which is moving the door toward the rear of the vehicle. Or, you could just remove all 12 bolts at one time and give it a big yank just to see what happens. | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | I vote for unbolting from the door. Messing with the upper hinge after unbolting from the body first is a true pain in the ___. I should know because I did the first one that way. The engine hoist and strap idea is genius. It would hold the weight of the door and let you pull it straight away from the body, not having to worry about it getting away from you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I found an easy way to support the door while unbolting the hinges was to tip a 5 gallon bucket upside down and slide iit under the door. With the glass out of the door it’s pretty manageable and not too heavy. | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | I found an easy way to support the door while unbolting the hinges was to tip a 5 gallon bucket upside down and slide iit under the door. With the glass out of the door it’s pretty manageable and not too heavy. That would work too, but you can't let go of the door completely with it partly detached from the hinges. Hanging the door from the top would let you never worry about it crashing to the ground. Height is infinitely adjustable as well with the engine hoist.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | Make sure you take the hinges too. Can't have too many spares. Someone will need them. They are easy to rebuild. Reproduction hinges are junk.
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Great info! I will not be able to bring my hoist (Great idea)... I will grab the original parts. Including hinges! Again, Thank you for All Input. I will post how it goes.
1950 Chevy 3100
