| | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | I offer this only as a heads up to those out there that have not yet painted the bottom rear valance. The originals had an about 1/2” hole at the center that was used to capture the hook shaped bolt that in turn captured the end of the spare tire carrier. There were two swagged fasteners used to hold a bracket to reinforce the valance. The repop valance is absent the hole and the bracket is spot welded. One of those spot welds is in the center of the bracket, where the hole needs to be. The problem, as I see , it is the two remaining .25” diameter spot welds after drilling a hole would seem likely to fail under the load expected they would carry? I will now need to drill a hole and two additional holes, one on each side to reinforce the spot welds. Then touch-up paint the bolt heads, and any damage related. Sure wish I’d compared the valances more carefully before painting!🤪 | | |
