4 members (Otto Skorzeny, KEVINSKI, Gray_Ghost, texas46), 179 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
#1300092 02/21/2019 11:54 PM
Hello fellow bolters,
I have the hood reinstalled on my 3100. It is time to latch the hood down but I am nervous about closing it right since I have read that if the hood latch and retainer don't line up that I will not be able to open the hood! Yikes!! Don't want that to happen! Any tips to keep me out of trouble?
Hello Jhyp,
I saw this clip on youtube and thought it might help you? Towards the end it talks about how to align the hood latch.
Hope it helps. Good Luck!
Charlie
'51 3100 5-Window (Restomod in progress)
Here's the words from the Service Manual for hood adjustment.
I had this happen last winter after I put the engine back in my 51 GMC. I was able to pop it loose from underneath with a piece of angle iron and a hammer. You can get under the front and see of you have that access too.
1951 1 Ton Completed
Jhyp #1300343 02/23/2019 10:53 PM
I was afraid of getting my hood stuck closed too, so I put a piece of masking tape across the latch bolt hole, then a dab of grease on the point of the latch bolt. I lowered the hood down until the latch bolt left its grease mark on the tape, then I could see which way the hood latch needed to be moved to be centered.
1951 Chevy Panel Truck
Sounds like a great idea - I'll have to try that one!!
Charlie
Miriclepieco,
I like the grease idea. I'll try it. Tkx
