7 members (Jays58, tricordati, Otto Skorzeny, KEVINSKI, Gazz, JW51, Shade Baby), 147 guests, and 3 robots.
Topics128,095
Posts1,056,468
Members48,444
Would like to keep my original headlight switch. Have truck all converted to 12 v. With the switch handle 12 v? If so any have a wiring diagram for it? It is marked battery and horn on 2 spots but no other markings. Thanks for any help. Bill
1937 GC
The change to 12 volts doesn't matter. Have you got a wiring diagram?
1951 1 Ton Completed
Not for the 5 screws on the back of the light switch.
1937 GC
Here is a picture of it
1937 GC
Ex Hall Monitor
Ex Hall Monitor
Thanks Tiny
1937 GC
I don't know about the terminals on your switch. However your ignition switch needs to turn the ignition and gas gauge on and off. The horn would not be switched. You can use an ohm meter to see how the switch works and go from there.
