Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Hello fellow bolters, I have the hood reinstalled on my 3100. It is time to latch the hood down but I am nervous about closing it right since I have read that if the hood latch and retainer don't line up that I will not be able to open the hood! Yikes!! Don't want that to happen! Any tips to keep me out of trouble?
Here's the words from the Service Manual for hood adjustment.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I had this happen last winter after I put the engine back in my 51 GMC. I was able to pop it loose from underneath with a piece of angle iron and a hammer. You can get under the front and see of you have that access too.
I was afraid of getting my hood stuck closed too, so I put a piece of masking tape across the latch bolt hole, then a dab of grease on the point of the latch bolt. I lowered the hood down until the latch bolt left its grease mark on the tape, then I could see which way the hood latch needed to be moved to be centered.
