3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#1299941 02/21/2019 1:27 AM
Want to do a little touch up on my 37 resto. Leaving original paint and rust but have a couple new parts and a couple of parts that are wrong color. Would like to spray a little original paint on these but not doing entire part and leave some rust. Can you fade paint with a air brush not leaving a direct line? Want some complete paint areas fading to rust. Also are the 20$ - 50$ ones any good? Any help would be appreciated. Thanks Bill
1937 GC
Moderator, Electrical Bay
You can do that Bill. The $20 to $50 ones? You might be just as well off getting a PreVal sprayer, thinning your paint and spraying carefully and lightly from a distance of 18 inches or so.
~ Jon
Thanks for the tip Jon. Looked it up on internet and think that may work with a little practice. Bill
1937 GC
It is a cheap alternative. I've used those things to paint tricky areas like firewalls when the engine, wiring, etc can't be removed...
Good luck.
~ Jon
