0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Want to do a little touch up on my 37 resto. Leaving original paint and rust but have a couple new parts and a couple of parts that are wrong color. Would like to spray a little original paint on these but not doing entire part and leave some rust. Can you fade paint with a air brush not leaving a direct line? Want some complete paint areas fading to rust. Also are the 20$ - 50$ ones any good? Any help would be appreciated. Thanks Bill
1937 GC
| | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | You can do that Bill. The $20 to $50 ones? You might be just as well off getting a PreVal sprayer, thinning your paint and spraying carefully and lightly from a distance of 18 inches or so.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Thanks for the tip Jon. Looked it up on internet and think that may work with a little practice. Bill
1937 GC
| | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | It is a cheap alternative. I've used those things to paint tricky areas like firewalls when the engine, wiring, etc can't be removed... Good luck.
