4 members (Chev4t6, Chip O, cmayna, Mike B), 59 guests, and 4 robots.
Topics128,180
Posts1,057,153
Members48,464
First, did the 3100 come from the factory with the SM420 transmission option? If so, does any one have any pictures of the transmission, drive shaft to rear end set up? I’m needing to see that set up as I plan to put the SM420 set up in my 59 3100.Thanks!
You can email any pictures to: [email protected]
It did.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Former Workshop Owner
My long box (59 Apache) model 32 has the factory SM420. A little different than the short box 31 model as the long box has a two piece drive shaft with a carrier bearing. My other 59 Apache which is a model 31 was butchered and hot rodded many years ago by a previous owner so it would be of no help to take any pictures.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
M Online: Content
The u-joint yoke bolts to the output shaft on the SM-420. Your trans should look like this one without the band brake...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks everyone for the information. Would anyone know the measurement of the drive shaft with the male spline that slides into the U-joint yoke on the rear of the SM420 then back to the rear end or where I can get one for my short base 3100. Thanks
Crusing in the Passing Lane
Best to measure your truck when ready and then get the proper driveshaft.
Ed
Big Bolt Forum Moderator
on a 59, your SM420 will just have a yoke on the back, as Mike B, no park brake on it. Ed is right, best once the rest of the drivetrain is in and truck sitting properly, measure length between rear end and rear of trans (in between the centers of the u-joint yokes), like where the center of the u-joint cap would be) and get a new one made or find one in a wrecking yard or from a donor truck.
Mike
