6 members (Barney1951, treegrower, TUTS 59, Gray_Ghost, cmayna, UtahYork), 85 guests, and 0 robots.
Topics128,067
Posts1,055,877
Members48,428
#1299127 02/15/2019 10:34 PM
My question for the group concerns the running board apron. The attached photo shows The apron from the underside. There is a threaded flange at the bottom and a punched hole at the top (where green tape is). Where do these two spots get attached to the frame? Again thanks for any help.
Jhyp #1299153 02/16/2019 1:10 AM
You're missing the running board apron support bracket that goes on the front end of each apron. It bolts to the running board with a carriage bolt (should be a square hole in the running board) and then to the apron with two additional bolts. It doesn't attach to the frame. See Section 11, Sheet 17.00 of the Factory Assembly Manual.
Jhyp #1299178 02/16/2019 3:27 AM
Thanks Kevin. Now I have to find the brackets.
Jhyp #1299179 02/16/2019 3:29 AM
Was wondering what that square hole was for. I'll check the manual.
