2 members (RLB, 51 3804), 126 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#1298775 02/13/2019 5:44 AM
I have more zippers then a pair of cargo pants
Plain & simply put, what is involved in upgrading to later model tie rod ends on a 51 one ton??
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Sid Drapal at Nostalgia Sid's Dropped Axles does this frequently, and he can probably give more detail, but basically the balls on the steering arms and pitman arm are removed, holes drilled for the studs on the new ends, and when he does it, he sends pre-cut and threaded tube to assemble a new drag link and tie rod.
Why is swapping to a non-adjustable tie rod end an "upgrade"?
Yeah, for me, it wasnt on my 53 3100, if it aint broke, dont fix it is my motto.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
My 1951 1 Ton came with the modern style tie rod ends and I believe that is what is listed in the GM specifications. Could you possibly be talking about the steering arm joints?
1951 1 Ton Completed
Yep, my mistake........
~ Joe
Moderated by  Dusty53
