My new truck finally arrived and now I'm trying to figure out just what I have. Please help identify it!
Its a Canadian built model 94-23, serial # 0942301085. Empty weight on the tag is 2605 lbs, max weight is 6000 lbs. This seems to imply its a 1-1/2 ton, but that seem like an awful lot for a long base pickup. I have a Canadian 1939 GMC shop manual that lists a 9400 series as a 3/4 ton. But this is a 1940 so I'm not sure what the 94-23 model means. I looked at the Canadian GMC serial number page on the OLDGMCTRUCKS.COM web site but that couldn't narrow it down.
Now the engine - it is stamped behind the distributor TT15949, I can see no other casting marks. The 1939 Canadian shop manual lists a 224 cu in engine for all the trucks, 9300, 9400 and up. But again, this is a 1940 so I'm not sure if this is still true. I've seen in other posts that Canadian trucks used 216s rather than 228s that American built trucks used. My id tag is somewhat damaged but I can make out most of the engine number - ...15949, so it appears I still have the original engine. But the question is - what is it, a 216, a 224 or a 228.
Help!
Steve
