5 members (RLB, MNSmith, Kilted54, Brian Moore, 1 invisible), 90 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
I read you can use a 4WD S10 rear ond on a 1950 Chevy pickup. Has anyone done this? If so, did you have to move the spring perches? Will they line up as is? Thanks!
Junior Member
Junior Member
I'm not sure about the S-10 width but people do chassis swaps using the S-10 for the AD trucks. However any 10 or 12 bolt from a mid 70's Camaro or Firebird will fit perfectly.
What ever you use it should be close to 61" backing plate to backing plate.
I used a s10 4wd blazer rear on my 46. I had to cut the perches and weld on new ones. A couple of things measure the width I know there are two widths 2 vs 4 wd and I have been told there are 3. Watch the ratios as rears with the OD trans. usually have lower gears. The axle tube are 23/4 vs the older camaro that are 3". Mid late 80's chevrolet they used clips to hold the break wheel cyl vs later models like the early camaro used bolts.
Well, I went and bought a 4.11 rear end from a 1984 S10 4wd Blazer. It is the correct width (60" from wheel hub plate to wheel hub plate). I did have to move the spring perches to the outside, 2 inches on each side. It fits perfectly. Once I install the engine and tranny, I will check the yoke angle to ensure it aligns with the transmission. If it doesn't, I will use shims. Thanks for the input.
