2 members (dunfire, baldeagle), 136 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1298293 02/10/2019 3:15 AM
Hey There,
I was turning the carb today and I realized that I don't think the valve cover is set up correctly. It has a breather type air filter on the back and the front is oil cap that appears to be vented. Smoke comes up out of the oil cap as it was idling.
Looking at pictures and other posts appear that a valve in the back should have a hose that runs to the carb or air cleaner. I have a rochester b single carb and it doesn't have any port to plug the hose into, should I look at replacing the air cleaner to fix this?
Any other ideas?
1963 C10 Fleetside Long Bed; 230; 3 speed; gun rack.
Matttttttttttttt #1298334 02/10/2019 3:56 PM
Riding in the Passing Lane
You should have a tube in the center port of the intake manifold. A 3/8 vacuum hose connects to this tube & goes to a PCV valve in the rear portion of the valve cover with a grommet. A breather oil cap goes on the front opening of the valve cover
Georgeeeeeeeeeeee.
1972 Chevy c10 Cheyenne Super
Matttttttttttttt #1298399 02/10/2019 10:57 PM
There are several prior PCV posts. Link to with information on installing and proper setup.
http://devestechnet.com/Home/PCVInstall
showkey #1299471 02/18/2019 5:45 AM
Here's what I did a year ago when I was rebuilding a 1967 327.
I have seen the Tech Tip where people have made modifications to the back of a stock style valve cover to add a port for a PCV valve on a SBC. That may work fine for some people, but I didn't want to modify an old stock cover if I don't have to. The originals are out there, but why mess them up if you don't have to. So I came up with a different method.
This will only work if you block still has the hole at the rear of the block for the Road Draft Tube and the hole in the intake manifold for the Oil Filler Tube. I had a '67 327 and it has both of these holes, but they are both blocked off with what looks like expansion plugs. Inside the lifter valley it will have a canister style baffle. (see photo RoadDraftHole.jpg)
Pull both expansion plugs and replace the front one with the Oil Filler Tube and breather cap. Make sure that it is a breather style with filter and no PVC port. (see photo OilFillTube_and_Breather.jpg) That's the easy part.
Since I am limited on the number of photos I can attach, I am placing the next set of photos in the message below this one.
The rear plug is a bit trickier and you will need access to some large drill bits or a small mill. Using the plug you removed from the Road Draft Tube hole, or a new one of the same size, drill/mill out a 15/16" hole in the center of it. (see photo RoadDraftPlug.jpg) My milling wasn't perfect, but will work for this.
Install a standard size PCV grommet in the hole (see photo PCV_Grommet.jpg) you just created into the plug. (see photo PCV_Grommet_Plug.jpg) you may need to trim the outside diameter of the grommet slightly.
I have a photo of the completed assembly showing the PCV valve in the newly created port. (see photo PCV_Assembly.jpg) This assembly can now be installed into the Road Draft Tube hole at the back of the block.
After installing the assembly in the rear of the block, the PCV valve can be plumbed into the back of the carb or one of the vacuum ports on the intake manifold. Your choice, as long as it has a vacuum source to run the PCV.
I don't know if this will help a lot of people or not. I'm not sure how many engines still had the road draft tube hole and oil filler tube holes plugged from the factory. It just seemed to be a cleaner way to do the installation. I am trying to make my '67 327 look as close to an old early model 283 as I can so that it doesn't scream "New Engine" in my '62 C10.
In the end, I had to trash the '67 block and go with a '63 block, but I still used all of the '67 heads, intake, etc.. so I followed through on this concept and brought it to life. I have been running it for over a year now and I've been very happy with it.
62Stick #1299472 02/18/2019 5:48 AM
Here is the PCV Assembly.
62Stick #1299473 02/18/2019 5:52 AM
Here's what it looks like when installed.
