| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 13 New Guy | | New Guy Joined: Jan 2019 Posts: 13 | Who knows where I can get a rebuilt or refurbished steering box for a 1954 Chevy 3600 4 on the floor??? Thanks. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You may have luck posting in the Swap Meet section (this assembly will be heavy and expensive to ship). I know Jim Carter lists them in the catalog, availability dependent. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's just replacing bushings and seals a machine shop may be able to rebuild yours.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brad, Where does Jim Carter now list that in his catalog? JC Catalog ListingKEV BB FARMS, Lares Corporation rebuilds steering gear/column assembles; however, they do not know the correct part for a 1954 truck. https://www.larescorp.com/Lares incorrect unit - same as incorrectly shown by Rockauto.com.If you call Lares they will assure you that they have your correct assembly - they do not. I'll tell you their BS reply/response to my query, if you ask. Rockauto.com had to help me to get Lares to take my steering boxes and rebuild them. Rockauto still does this, and/but the price with shipping ia around $1,000.00 Rockauto listing - note the wrong unit in the photo - from Lares Corp.I'd try to follow Tiny's advice - see if you can find a local machine shop that seems to know what they would be doing. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Tim, I have an old one (printed) and it was and continues to be offered as they become available, no part number you have to call them (they are listed on the Used Parts pages, back of the catalog). | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Is the 3600 a one ton? If so The Filling Station has a rebuild kit for under $80. <CLICK>
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3100 1/2 ton 3600 3/4 ton 3800 1 ton
Maybe someone will check a parts manual to see if they are the same stearing gear column/assembly? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Their listing says it's for 1/2 to 1 ton so it should work.
| | | | | Joined: Jan 2019 Posts: 13 New Guy | | New Guy Joined: Jan 2019 Posts: 13 | Thank you guys. Classic Truck Parts has one on their online catalog but out of stock. Does anyone know the difference between the 4 speed box and the 3 speed box ????? | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Isn't the only difference between 3 speed and 4 speed the tube in that the 3 speed and H-M has drilled and tapped holes for the shifter to mount to the tube? and the 54 tube has a provision for the turn signal wiring cover?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Greg
I forgot about that detail. | | | | | Joined: Jan 2019 Posts: 13 New Guy | | New Guy Joined: Jan 2019 Posts: 13 | I'm not worried about keeping it "original". So is that a yes that the 3 speed will work ?????? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2016 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,044 | I bought a kit for my 53 for about $80. I bought new balls for it from Mcmaster for a couple of bucks and the local machine shop charged me $20 to install it.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Apr 2019 Posts: 51 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 51 | Hi All, I just bought a 56 3100 and have a lot of questions. I'm starting with the steering as it is very sloppy. I took the truck to an old time mechanic who told me the king pins were good but the steering box is shot and needs replacement. I called around and cannot find one in stock. I could send mine in for a rebuild but the truck would be out of commission for some time. I would like to know, is there a good source to buy a rebuilt steering box? I find rebuild kits available. How difficult and time consuming is it to rebuild one, assuming an experienced mechanic is doing the job? Any advice is most appreciated.
Bisongno niente. Voglio Tutto.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | https://www.larescorp.com/And, Rockauto.com sells/sold the Lares products (note the incorrect unit/style). Rockauto might ship yours to Lares, and then you know yours is correct for your year. Lares shows an incorrect 1954 truck steering box - they told me that the four 1954 trucks/units that I had were all incorrect. They were, of course, wrong. I sent mine to Lares via Rockauto. They came back in beautiful condition. Lares will return them in primer or in black. Note: I did those in 2014 | | | | | Joined: Apr 2019 Posts: 51 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 51 | Thanks for the info! I called Lares. I'm having a hard time determining which box is the correct one. I have a 56 3100 2WD with a 6 cylinder engine. They suggested sending mine to them for a rebuild but I don't want to take things apart just yet. Is mine what is called a two-ten series?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Check with your closest Autozone. Cardone brand shows refurbished units available through Autozone.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 210 series is most likely a reference to a car model. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | In case you didn't know, your steering column and box are one unit, the column is factory pressed into the box. Have you tried to adjust the box per the shop manual? That's where I'd start. Mike B  | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | They are not too difficult to rebuild either.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955 2nd series and 1956 use the same box. 1957-59 have a shorter column.
See the USA in your vintage Chevrolet! My Blog | | |
