7 members (moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl, Otto Skorzeny, Phak1), 130 guests, and 2 robots.
Topics128,114
Posts1,056,283
Members48,439
I have a 1955 second series pickup. The truck has a 1978 Camaro front suspension with disc brakes. I'm going to install new springs that will lower the front by two inches. Does the two inch change require a specific front shock? I plan on having the front aligned, however. Will the reducing the size of the spring have an impact on my steering? Thanks a lot for answering. You have given me some great advise in the past.
Pete
QA1 is one option to consider. There staff can explain the different adjustable shocks available and coil overs with the correct spring rate for your desired application.
Shocks are sized according to the travel limits. Most things I read say to have 2/3 of total travel in compression, and 1/3 in extension. So after your spring change, you will need to measure how much actual travel the a-arms have before bottoming out. You want slightly more shock travel then you have a-arm travel so the shock never hits its internal limit. The only thing that should change with lowering ( spring change ) is chamber and maybe a little toe-in, a good alignment shop should be able to compensate for any difference. It should not effect steering effort or geometry. What you may find after the change is the ride is much stiffer, spring rates change with lower springs, they have to or it would bottom out all the time.
They are plenty of Firebird / Camaro sites that sell lower kits for the '701/2 - '81 F- bodys, so finding shocks to match the springs shouldn't be an issue, this would also be a good time to replace all the bushings if you haven't done so already. The Poly bushing kits really tighten up the front ends!
Joe
1951 Chevy Panel Truck
