3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
Are the frames the same, just foam & spring differences?
Just the covers would be different
Spring layout is different.I have both seats.My deluxe seat frame is in rough shape and all of the foam is gone. I was wondering if i could put the deluxe springs in the standard frame, add foam and have a deluxe seat.
Correct. The deluxe springs are lower/flatter to allow for thicker, molded foam. At the ends of the seats, however, about a 4"-5" section of the springs are higher. The foam has a section on the bottom missing for that section of springs.
Not sure of the frame. I would imagine it's the same, just the springs are different.
This is what I was talking about on the sections of foam.
Thanks, that is what i needed to see.Is there a source for "premolded foam" for these?
