7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
#12979 05/15/2003 7:26 AM
JUST PICKED UP A HEAVY TRUCK, MAYBE EX-MILITARY. I6 GAS ENGINE, CAN'T FIND TIMING MARK OR FIRING ORDER (TRIES TO FIRE). HAS 5-SPEED. "KICK" START BUTTON ON FLOOR, 12-VOLT. BELIEVE IT HAS 302 C.I. THE CARB HAS 2-BBL WITH 2 LAYERS OF FLAPS. PLEASE HELP ME MAKE IT RUN! THANKS!
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#12980 05/16/2003 12:35 PM
You'll find ID data on my website which might be helpful. It's under Serial Numbers, then under '55-59 ID data.
#12981 05/18/2003 5:16 PM
WHY IN THE WORLD WOULD YOU REFER AN OWNER OF A 1956 TO YOUR SITE WHICH CLEARLY STATES IT'S ONLY 1955 & OLDER. NO HELP AT ALL.
