| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12979 05/15/2003 7:26 AM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | JUST PICKED UP A HEAVY TRUCK, MAYBE EX-MILITARY. I6 GAS ENGINE, CAN'T FIND TIMING MARK OR FIRING ORDER (TRIES TO FIRE). HAS 5-SPEED. "KICK" START BUTTON ON FLOOR, 12-VOLT. BELIEVE IT HAS 302 C.I. THE CARB HAS 2-BBL WITH 2 LAYERS OF FLAPS. PLEASE HELP ME MAKE IT RUN! THANKS!
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#12980 05/16/2003 12:35 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | You'll find ID data on my website which might be helpful. It's under Serial Numbers, then under '55-59 ID data. | | |
#12981 05/18/2003 5:16 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | WHY IN THE WORLD WOULD YOU REFER AN OWNER OF A 1956 TO YOUR SITE WHICH CLEARLY STATES IT'S ONLY 1955 & OLDER. NO HELP AT ALL.
