6 members (Ponchogl, 48ed56pam, Bill Marlow, Hanks custodian, frogfarmer, 2-Ton), 246 guests, and 0 robots.
Topics128,081
Posts1,056,071
Members48,434
#1297781 02/06/2019 5:01 PM
Removed the engine.
Removed the front clip.
Degreasing the frame and noticed the stock rear cross member (where the bell housing mounts) has cracked completely away from itself at the 2 upper most rivets, (one on the left and one on the right) on the forward facing edge of the piece. The rivets are still very secure, and there's easily enough of the cross member still held in place by the rivets to be welded back on. They appear to be the only compromised area of the piece. Do I just weld them back together? Also, there's a crack between the 2 holes that the radiator core support bolts to the frame. Just weld that up too?
All advise welcomed!
1949 3600
Don't sweat the petty things, and don't pet the sweaty things.
Never play leap-frog with a Unicorn.
2 Wrongs don't make a right, but 3 lefts do.
Of all the Henges, Stone is my favorite.
If at first you don't succeed, skydiving is not for you.
Here's a word I just made up.....Plagiarism.
1949 3600?
What engine & what transmission & what clutch housing?
Sir Searchalot
Sir Searchalot
Very slightly groove the crack, not deep and don't create a wider crack. Drill 1/8- 3/16 dia holes at the ends of the cracks and then weld it all up. Maintain bell housing hole spacing if you think that is a problem. Possibly by bolting it back on by itself. Pull crack back together before welding if it is separated. If it can not be pulled back fairly tight, a different fix may be necessary. Hard to tell the size and extent of cracks/breaks without pics.
Prepare area to shinny metal for mig. Not necessary for stick.
Pulled a 261, sm420. Wasn't aware more than one bell housing would work. It fit on the cross member without modification, as the mounting holes in the cross member are still round, and there are only 2. It has a little peep door on the top...
Plan on rebuilding the 261 & using the same bell housing with a T-5 if it matters....
1949 3600
I'll get pics as soon as I can!
1949 3600
Sir Searchalot
Sir Searchalot
If it's just a crack, it can be welded no sweat................. but "cracked completely away from itself" is something we need to see.
I get it.
That's why I posted here, and didn't just weld it.
I'm currently working, but will get pics ASAP!
1949 3600
Sir Searchalot
Sir Searchalot
Understood.
The nuclear option is to drill out all the rivets and weld it off the truck with plates or gussets. Another is to bolt on a good, solid, donor cross member. I would probably never do that. But never say never because you never know.
That's the thing...the rest of it looks great! All the rivets are clean and straight, the frame rails have no obvious damage. Just the upper most, forward facing one on the right, and it's mirror on the left!
1949 3600
Sir Searchalot
Sir Searchalot
Looks like the design on that cross member is rivets into the web of the frame channel and rivets into a hang down wing bracket. Wing bracket is riveted to the lower flange of the frame channel.
Sounds like clean, grind, and weld in place type job to me. Weld the crack, don’t weld crossmember to frame.
These are often cracked in some form or another.
•1952 Chevrolet 3800 pickup
---All pictures---
Check for indication of impact to the front or rear of the crossmember. I can't wrap my head around how that much damage to that stout of a crossmember without a significant impact having occurred at some point.
I suspect vibration, time, and expected frame flex did the job.
I’ve seen several AD transmission crossmembers cracked near one rivet or another with no obvious abuse.
---All pictures---
Let's see if this works for pics...
https://www.flickr.com/photos/168125184@N07/shares/r59Z13
No damage other than the cracks. This is just one side, the other side is identical.
1949 3600
Sir Searchalot
Sir Searchalot
Can see horizontal crack, can't see if there is a vertical crack because the lighting is shadowed. Probably is a vertical crack. What I see is no problem for welding. Good fillet bead, no grinding. If a person had no welder available, you could possibly put one or two socket head cap screws thru member and frame. Under the crack, 1/4-20.
As Grigg said, welding on the frame is to be avoided. Stay on the cross member. You don't need a mega weld. Forget what I said about drilling a hole at crack ends/grooving/pulling. Good you gave us a pic, it did sound way worse.
As said, it lasted a long time thru endless vibration and twist. If there is more to it than those cracks at one rivet/cross member ear, each side of truck, point it out. Those ain't nothin.
"Cracked Cross Member" My first thought; Who's he talking about smile ? Gotta get More coffee now.
RonR
1970 340 Duster
1964 CJ5
As mentioned frame and cross member cracks are very very common. The factory predicted that it would happen.........
There’s a whole section in the factory shop manual on repairs. Welding, plating reinforcement is the common solution.
All great info.... thanks fellas!
Before I weld, I'll make sure the distance between the top of the frame rails is the same as the distance between the bottom of the frame rails.
Sorry for such dark pics....
1949 3600
From the look of the way the section of flange just under the crack/break is pulled away from the inside of the frame rail I'd be willing to bet it never fit properly when it was originally put together. Then after a few years of twisting and working a crack appeared due to the added tension of the poor fit.
Just my $.02 for what its worth. I suspect if its welded back together just the way it sits there will be no more odd stress on the joint and there's a good chance it won't crack again.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
