| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 40 | have a 62 c40, technically a 1.5 ton but looks more like a C30 than a C50/60 it has the independent front suspension, 10 lug 19,5s
will pieces from a later disc brake truck fit or is it an entire cross member swap
thanks in advance
I hit cars with hammers
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | GM had later model independent front suspensions with disc brakes and 5/10 lug on 7.25" same as your bolt pattern. Often found in bread trucks and such but obviously without the I-beam axle. I have no idea what might be interchangeable. Probably worth looking into. | | |
