1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1297685 02/05/2019 8:07 PM
have a 62 c40, technically a 1.5 ton but looks more like a C30 than a C50/60
it has the independent front suspension, 10 lug 19,5s
will pieces from a later disc brake truck fit or is it an entire cross member swap
thanks in advance
I hit cars with hammers
GM had later model independent front suspensions with disc brakes and 5/10 lug on 7.25" same as your bolt pattern. Often found in bread trucks and such but obviously without the I-beam axle.
I have no idea what might be interchangeable. Probably worth looking into.
1952 Chevrolet 3800 pickup
---All pictures---
