5 members (55shaker, FAST55, WICruiser, Rusted Nut, MickeyP), 179 guests, and 3 robots.
Topics128,078
Posts1,056,051
Members48,433
#129765 09/24/2003 12:21 AM
I
I Offline
http://community.webshots.com/user/ifrizlfri
Look at the frame pictures. There are some shots of the Passenger side.
This thing is a pain. How do I level it? Should I compress as far as I can and let the Shock try to hold it there?
WHat is wrong here? I want all the input I can get
good bad or indifferent.
And no I dont know what I am doing.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
The only thing I see wrong is the T-bolts holding the upper A-arm to the top hat are backwards. The Tee side goes on the bottom and the nut goes on top.
Everything else looks fine to me...just install the shock for now. You just need weight on the front suspension and little by little the lower A-arm will move toward being parallel with the ground. I hope your running V-6 springs with air and not the v-8 springs.
Joe
Joe
See my post about TCI spring problems (you'll have to 'show topics from last 60 days' - in this forumn. They need to be broken in. If you look a little farther back in this same forumn - then you can find some suggestions on how to compress springs. They are good ideas.
You can also look at my web page that's in my sig. It shows a similar problem.
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
Junior Member
Junior Member
Yea, you need to turn "T" bolts over, nuts go on top. Looks good other than that. I didn't put my springs in till I was almost done with the truck. I measured and cut a piece of (I think 5")thick wall PVC pipe, and set in place of spring ,to set everything to proper ride height, then finished building truck. It seemed easier setting up drive line when everything is at proper level? I had same problem, Good luck, looks like a nice job.
"Boop-Boop-a-doop"
#129769 10/02/2003 10:36 PM
Z
Z Offline
Mine was the same a nightmare trying to get spring compressed and into place with a spring compressor on spring, went partial compress then an all thread thru tower and a plate thru spring, takes courage because the plate unwound up the spring once. It has been six months with cab engine and chassis pretty well done and it has settled some, with everything on I'm hoping it'll be there. Seems the older I get the slower.
Zeker
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
