4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#1297523 02/04/2019 1:29 PM
I have a 58 Chevy step van that is a food truck. It has a fair amount of weight in back and was looking for some heavy duty/commercial shocks that would fit a 3400. I found some Gabriel's that will work ok, but wondering if there are any other options. I welcome all opinions.
1958 Chevy Grumman Olson step van
Just a note........ shocks don’t carry weight. They control rebound. Exception is shocks with springs or air shocks.🛠
Yes, I'm just thinking of something that will be a little more rigid for corners and such.
Sway bars would help restrict body lean in corners. Or you could put air bags on it to level it up. As Martin said, shocks don't carry any load.
All a set of stiffer shocks will do is make the ride harsh and beat up whatever cargo you're hauling. If you want more stability in turns, install a rear anti-roll (not sway) bar. It's a U-shaped bar that attaches to both frame rails and to the rear end at the spring plates. It allows unrestricted up and down motion of the rear end when hitting bumps, but it restricts body roll in a turn. Heavy duty bars front and rear will add stability without making the ride rougher.
That's what I meant. If that isn't a sway bar, then what is? I have a feeling it's just semantics.
A "sway bar" is actually a Panhard rod, a straight bar which attaches to the frame on one side, and to the rear end housing on the other. It prevents side to side movement of the body and frame, relative to the rear end. Both types of bars have their uses, but a Panhard rod won't reduce body lean in a turn.
https://en.wikipedia.org/wiki/Panhard_rod
https://en.wikipedia.org/wiki/Anti-roll_bar
On our Advance-Design Trucks/Stovebolts, GM called it a "Ride Stabilizer", or, "Front Stabilizer".
That terminology was used by GM through 1957, at least.
Yep, Semantics wink
From the wikipedia link: An anti-roll bar (roll bar, anti-sway bar, sway bar, stabilizer bar)
Panhard bar: AKA Track Bar isn't what I would call a sway bar either.
Oops, I was referring to a front-end stabilizer. dang
My bad - sorry.
