9 members (Bizaircon, Youngin' Tut 59, klhansen, J Lucas, Hotrod Lincoln, 5 Window 9434, lumbersawyer, DougH6100, 1 invisible),
78
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | This little sidetrack mission started with trying to change the barings.......
Another BB member told me that the 1962 Chevy C10 hubs have roller barings and fit on the 1960 GMC/Chevy Spindles. If I can confirm and find these hubs I'll make the switch. Another member told me that making the witch would help improve highway speed issues as the OEM type ball baring really don't like being driving long distance at 60+mph. But I'm trying to see if they come with 6 lugs for my rims.
Any leads ya'll have for the 62 hubs, I'd appre. will start the parts house serve asap.
Thanks Jake | | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Don't bother. There's nothing wrong with properly maintained ball bearings, and whomever is spreading the myth about highway speed needs to come talk to my garden this spring- - - - -I'll save a fortune on fertilizer! The only downside to ball bearings is the cost, but if you clean and repack them every couple of years, they will last for decades. Jerry
| | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | I'll agree, ball bearing are fine. However they are expensive, not as easy to find on the shelf of most FLAPs as taper roller wheel bearings. Easy enough to convert, get hubs, dust caps, bearings & seals from a newer C10, '62 - '66, perhaps later.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
