| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 57 | So, when trying to decode VI, 0 C 25 9 K xxxxxx
0 =1960 C = 2WD 25 = 3/4 ton this 5th digit is TYPE, apparently 4 = pickup. Mine is 9. K = Kansas City
What is type 9 ? Assuming it somewhere says 'STAKE' because that what it is. But I can't find a verifying explanation of TYPE 9.
1960 C20 Platform
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | C2509 is a Stake Model Truck According to Page 85 in the 1960 Chevrolet Trucks link on this page: GM Heritage Center Info Kits
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2016 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 57 | Thanks so much. ( I knew I saw that .PDF somewhere ... then lost location ) Does this make it 'rare' - being stake truck ? I've never seen another in-person or online.
1960 C20 Platform
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, that would be an uncommon/rare truck.
That does not necessarily mean it is a more valuable truck than a smaller, more common/desirable truck. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I know for a few years in the mid to late 50s Chevy offered Heavy Duty 3/4-ton trucks with dual rear wheels. Did that continue into the 60s? I looked at the GM Heritage link above but did not see it. Thanks.
Edit: I found the answer on the GM Heritage site linked above - yes they did over dual rear wheels on C20 3/4-ton non-pickup models. Thanks.
Professional Novice
